F.s is a pair of brand new never used 300zx rotors that have been drilled to fit 4 lug Sold
Adjustable fuel pressure regulator asking $60 almost new
28mm?
yes 28 mm they did make 28 mm rite?
Nope, 26mm or 30mm.
you sure?
well i have rotors for a 300zx that say 28 mm
whats your location?
Are you use the 0 isnt missing ?
Z32 rotors are 280mm x 26mm or 30mm… they never made ANY in 28mm
They could be the 30’s with a maximum usable thickness of 28mm
i belive that is right
afpr still for sale? if so send pics
Mike is right, the 30mm calipers have 28mm stamped on the rotor, the 26mm calipers have 24mm stamped on the rotor.
http://moredhel.net/3z/brakes.html
take a look at my chart, some of the nissan calipers model numbers are listed… you’ll note there is no precise correlation to caliper width, and that’s because the caliper brackets can be very different, and the pistons and pads can be larger or smaller to take up the slack…
on say a truck with the chance of overheating the brakes with agressive foot stomping (like during towing) they may opt for thinner pads and larger rotors for the increased thermal mass, with the tradeoff being more frequent pad changes
on a light passenger car they may do the opposite, large pads and silly little rotors getting closer to a long and equal service life for both parts
addendum some rotors are stamped with minimum thickness, but it’s not a rule
hey, I’d like to buy those rotors from you. pm sent.
