F/S: Civic & turbo parts!
D16Y8 Head
About 90xxx miles on it
SOLD
D16Y7 head
About 120xxx on it
$50 with valve cover
Bare D16Y7 intake manifold
$20
D16Y7 automatic throttle body
Has IACV and all sensors still attached
$30
Garrett T25 Turbo
Came off of a 2nd Gen DSM. Unknown milage, but has very minimal shaft play
$100 - PENDING
Turbo XS RFL Blow Off Valve
$100 shipped
Front Mount Intercooler
Needs endtanks welded on. 6 out of 10, condition wise.
$45
Bare D16Y7 block
Was in my Civic, changed the oilpan gasket, and wouldnt start. Everything LOOKS ok, but hasent been tested or checked profesionally. Comes with girdle and crankshaft.
SOLD
D16Y Waterpump
Under 10k on it. Was put on my Civic last fall, and taken off 2 months ago
$25
D16Y Timing Belt
Showing no signs of wear. Same amount of milage as waterpump.
$20
B18b1 Intake Manifold
No injectors, fuel rail, or throttle body
$30
99-00 Type-R Style Grill
SOLD
D-Series Shift Linkages
$30
D-Series Power Steering Pump
$35
OEM Dual Din Block Off Plate
$35 shipped
99-00 OEM Radio Pocket
$25 shipped
D-Series Waterpipe & Thermostat housing
$30 shipped
D-Sereies OEM Spec Exedy Clutch Kit
Clutch disc still has good meat on it, but the p/p fins are kind of warn from the T/O bearing. None are bent tho. No slippage or any issues when I had it on my D16
$40
D-Series Stock Flywheel
OEM flywheel, with good surface.
$20
Exedy Clutch Kit & OEM Flywheel
Package deal if you buy both
$45
HKS Turbo Timer
Type-0, Black in color, harness has been cut, but still in 100% working order. Very good condition
$75
92-00 Civic A/C System
Includes all the lines, compressor in working condition, condensor, ect. Everything but the evaporator under the dash.
$75
Pics available upon request, all prices OBO. Will add more as I find things. Looking for trades as well. B18 LS hydro tranny, B18 shift linkages, OBD2b LS ECU, ect.
Jeff, you better jump on these before Paul does :ohnoes
looking for b16 stuff plus i already have a turbo, and its currently a stand to work on my r/c car on the coffee table
Up
Bump. Listed on craigslist, and soon to hit eBay (even tho Id rather not).
Y8 head and Y7 block sold
Bump. Added more stuff
Price drop, and added items.
Up
Up. Added more stuff
Bump. Added A/C system
Still got the timer?
Yes’sir
Up
Up
