Allright so my car is a 200 SX but the problem I am experiencing should be somewhat generic. I am having problems with my dashlights, particularly the signal lights. I seem to be loosing voltage somewhere, im not sure how or where. When i look at my volt meter on my dash it is always ticking back and forth, then when i put on my signal lights it bumps almost all the way up and down. This affects my tach and everything it seems when the system is under a big load stuff starts fluttering and going weird.
I have swapped out the signal light switch and flasher, this made no difference.
Some people have suggested that it might be the alternator, but I had this probelm before my SR swap… so with another alternator it did the same thing.
Any suggestions at all would be great!
Thanks in advance Craig
