yupz like the title says i have a 180sx front brake set for sale.come complete and good pads
$180 pick up only
$180 pick up only
abs/nonabs?
are these the excatly the same as stock breaks??
non abs.
they have bigger rotors and better braking
brakes*
no they’re a bit better, no where near Z32 brakes but a nice simple upgrade. they use a mid 90’s Altima Rotor and a ??? Maxima Pad.
I have them on mine, i like 'em.
Fitzy
have pic… wanna look at the condition (i know they’re good,but wanna see how good)
Yeah, post a few pics…
[/quote]
Actually this setup is pretty close to a Z32 Brake Setup considering a 180sx Rotor is 280mm X 22mm and a Z32 Rotor is 280mm X 26/30mm “depending on your caliper” its pretty friggin close… only real difference is the single piston vs the 4 pot setup.
A 180SX brake setup is an awesom upgrade over stock thou… the bigger rotor dia alone gives more stopping power and then throw in the bigger piston dia and it actually is a very nice setup for much cheaper then a Z32 setup. Then on top of it, you dont have to worry about clearance issues like you would with a Z32 Caliper
[/quote]
A 180SX brake setup is an awesom upgrade over stock thou… the bigger rotor dia alone gives more stopping power and then throw in the bigger piston dia and it actually is a very nice setup for much cheaper then a Z32 setup. Then on top of it, you dont have to worry about clearance issues like you would with a Z32 Caliper[/quote]
Jedi, your forgeting that you do not have factory pads, but upgraded pads, this makes a huge difference
Actually… their OEM pads because if you remove them and flip them over you can still see the Nissan Logo + Part # on the back ![]()
soyy guys no pics due to the fact i don’t have a camera =( anyhow you can come take a look if you like
sold mods please lock
