I can vouch for these brakes. They are probably the best bolt on upgrade 240sx owners should go with. No need to get conversion lines i.e. 300zx front brake swap and no need to change the brake master cylinder as well. Keeps the brake bias as it should be. I had them on my 240 when I used to track it a lot.
Hey I have a 240sx 95 auto. trying to convert to manual. would s13 clutch and brake pedals work on a s14? if yes ill come tomorow. I also need slave cylinder and clutch cylinder and driveshaft for s14. Thank you. 647 588 5122 Sath
