Can you use S13 Manual parts to swap a S14 from auto to manual?
If so will they bolt right on… or is there some modification involved. (can u use a 93 KA tranny on a 95 KA?)
As well, are the CMCs the same on 180s as 240s?
i did search this but found no stright anwser.
tranny pressure plate, clutch flywheel = yes
speed sensor driveshaft = no
clutch pedal = have heard it can be spaced from the firewall with washers to make it work
Slave and MC = buy these new for less than $100 @ napa
hard/flex line = might as well get a stainless braided flex line $50? hard line(unbent) $6@napa
You have to make spacers for the clutch but it will work.
S13 hard clutch line will also work, just needs some gentle massaging.
could you say use a front clip from japan’s clutch peddle?
if the clip is a S14?
I sold my JDM S14 clutch pedal to someone and he told me it was unusable for the swap. I do not have any exact details why. Hopefully someone else has more of a definite answer.
A new one form Nissan is like $45. Save yourself the hassle and grab a new one.
YES. I have installed one into my brothers S14
