Brake Pedal and Clutch Pedal
For s14 u have to get the console piece from the dealer for shifter
shifter and all hardware…suggest some kind of short shifter
Steel line for clutch line to slave cylinder (roughly 9 feet and fittings)
Flaring Tool to put the fittings on (rent one at canadian tire)
Clutch Master Cylinder
Slave Cylinder
5 speed tranny
Clutch Kit, recommend brand new because you dont wanna have to change it. (clutch, throw-out bearing, and pressure plate)
Flywheel (if old one would need to be machined for cracks)
s14 manual speed sensor (since the s14 auto IS NOT the same)
Gear Oil (75w90 synth or 80w90)
Thats all i can think of at the moment
Labour:
All in all its not a hard swap to do when you have done a couple of them but each time new problems occur. If you are not very mechanically enclined i suggest getting someone who has done one before do it. If need be i can give you a few people who can.
