Hi,
Well, it’s been little over 6yrs since buying the car and I’ve had lots of fun, good memories with it, but it’s time to move on.
I won’t bore you with nostalgia, so on with the specs/pricing/pictures. Hopefully I haven’t left any detail out.
The ad is also viewable from http://www.my240.com as it’s easier to view the pictures than clicking each one in this thread
Let’s keep the trolling in this thread to a minimum ( I am of course the admin so watch out!
ASKING PRICE: $6,700 AS IS (O.B.O.)
- WILL NOT BE PARTED OUT
- NO TEST PILOTS WITHOUT DEPOSIT (Amount TBD in person)
- Location: Brampton (Delivery TBD in person after deposit)
- E-mail: gautam@rogers.com
- Cell: 416-294-9269 (Call anytime)
- Availability: Anytime after 7:30pm Weekdays, Anytime Weekends.
- Items marked with ** below can be removed from sale to lower final price of vehicle. Details subject to change without notice.
- Should have no trouble passing safety
Click thumbnail to view a larger image
– Brief Specs –
1992 S13 Coupe w/ S13 Blacktop SR20DET. Clean inside and out.
AEM EMS on MAP setup tuned for 18psi
Tubular SS manifold, Garrett T3/T04E 50-trim turbo (HPC coated turbine),
Turbosmart 38mm wastegate, Precision FMIC w/ full SS piping
Whiteline suspension, Z32 brakes, D2 coilovers
Full stereo upgrade (speakers, headunit, subwoofer, amp)
– Detailed Specs –
Body / Chasis
1992 Nissan 240sx LE Coupe w/ ~200KM on body
S14 cloth seats - excellent condition (original S13 brown leather included)
Compression numbers (estimate): 165-165-170-165 as of May 10, 2009 (new spark plugs installed)
Powered sunroof
No surface body rust and cleanly maintained
DTRL removed, USDM grills inserted
Spare tire and rear carpet removed
Rebar removed (included if wanted)
Windsheild washer fluid removed (included if wanted)
AC system removed
Engine
- 1998 S13 SR20DET Blacktop (as sold by Varun)
- 25-35KM on motor since install in late-2005
- GM 3-bar map sensor
- GM IAT sensor
- 740cc Nismo Injectors
- 255lph Walbro fuel pump
- AEM DryFlow conical intake
- Zirgo 16" electric fan
- Z32 fuel filter
- Koyo radiator
- Greddy RAS
- Circuit Sports overflow can
- Greddy style baffled oil pan
- Catch can (unknown brand)
- Firesleeved vac hoses and brake lines near turbo
- Re-hosed all water lines under intake manifold
- Throttle coolant line removed
- NGK BKR7E-11 @ 0.028" gap (changed 2x-3x a year)
- Mobil 1 synthetic (5w30 or 10w30 depending on weather)
- Nissan OEM SR20 oil filter
- OEM Nissan Upper/lower intake manifold gasket (uninstalled)
- OEM Nissan throttle body gasket (uninstalled)
Electronics
- AEM EMS
- Autometer Phantom 52mm electric Oil Temp gauge
- Autometer Phantom 52mm electric Oil Pres gauge
- Autometer Phantom 52mm electric Water Temp gauge
- Autometer Phantom 52mm vac/boost gauge
- Autometer Phantom 52mm EGT gauge only (no sensor/harness - uninstalled)
- Innovate wideband w/ G2 gauge (Gauge not hooked up)
- Optima yellowtop battery w/ custom heavy duty steel battery tray
- Alpine CD/MP3 headunit w/ propietary AUX cable
- Infinity 6.5" speakers front+rear (front: components w/ door mounted tweeters, rear: 2-way)
- Alpine Type-R Subwoofer in custom box **
- Alpine 350W RMS mono amplifier **
- Custom 300W inverter installed in glovebox w/ dual outlets
- 0/1 Gauge positive battery cable directly hooked up to starter from battery
- 0/1 Gauge negative battery cable directly hooked up to front block from battery
- S13 analog gauge cluster. (LCD/HUD stopped working. LCD cluster included if wanted)
- Engine harness fully reassembled, re-pinned, and neatly soldered, heatshrinked and taped
Turbo Setup
- Garrett T3/T04E 50-trim (60ar compressor, 63ar turbine), 360-thrust bearing, 4-bolt outlet, HPC coated turbine housing - http://www.hpautoworks.com/index.php?main_page=product_info&cPath=34_91&products_id=68&zenid=f6d13820b58be027e814042bb771085e
- Turbosmart Ultra-Gate38 wastegate, Black, w/ 7psi spring (retail box w/ extra springs and spare 38mm flange included), SS vacuum lines, open wastegate - http://www.turbosmartonline.com/index.php?id=54
- Turbosmart BOV, Red, (Mitsubishi Dual Port #TS-0205-1020) - http://www.turbosmartonline.com/index.php?id=46
- Hallman in-cabin boost controller, Black- http://www.hallmanboostcontroller.com/index.html
- Function7 restricted oil inlet fitting (#F7T34-R4) - http://www.function-7.com/products/turboparts
- SS 10AN oil return line and -4an feed lines (Earl/Aeroquip fittings)
- Tubular SS exhaust manifold
Suspension / Drivetrain
- B&M shifter
- ACT Heavy-duty pressure plate w/ unsprung 6-puck clutch
- D2 coilovers w/ 7/5 springs
- Whiteline front+rear swaybars
- Whiteline urethane bushings, endlinks and subframe spacers
- CP Racing 4-point front+rear strutbars, Baby Blue (front not installed)
- Project Nissan engine mounts - http://www.projectnissan.com/shopping/pc/viewPrd.asp?idcategory=0&idproduct=4289
- Nismo tranny mount
- 5-lug using S14 front spindle (Moog balljoints), Z32 non-TT rear bearing
- Custom coilover bolt sleeves (to use S13 coilovers on S14 spindle)
- OEM S14 wheels w/ Falken FK452 front, Falken 512 rear (205/55/16)
- Custom SS clutch line from master to slave
Exhaust
- Mr. Gasket copper exhaust gasket
- 2.5" SS downpipe w/ 4-bolt steel flange (purchased from http://weirtech.ca/)
- 2.75" Cat-forward SS exhaust (unknown brand. cat-forward = no space for cat or testpipe)
- Megan SS secondary downpipe w/ flex pipe
- Vibrant SS O2 bung
- DEI Exhaust wrap on downpipe and wastegate dump tube
- All piping tig-welded by a good friend
Intercooler
- Precision 2.5" Intercooler (350hp model #053-1005) - http://www.precisionturbo.net/Wc21126d5f695d.htm
- Full 2.5" SS FMIC piping w/ with beaded ends and Vibrant black couplers and wormgear clamps
- Custom steel bracket
Brakes
- Z32 iron 30mm calipers, front
- Russell brake lines, front
- SS brake lines, rear (uninstalled)
- EBC cross-drilled rotors, front
- Hawk HPS pads, front
- Hawk HP+ pads, rear (uninstalled)
Bye!
