Year:1997
Make: Lexus
model: SC400
Mileage: 133kmi
Color: Diamond white pearl
Interior: Black leather (extremely rare on a white 97), Black cloth reclinable racing seats( will also include stock black leather heated passengers seat), power memory steering wheel, dimming side view and rear view mirrors, Works bell short hub, airbag delete kit, NRG Gen 2.5 quick release (can easily be returned to stock 100% working order). Nakamichi sounds system w/ OEM 12 disc cd changer, white 330mm wood steering wheel, harness bar, floor bar, 5 point sfi approved harness
Exterior: Vertex Ridge knock off wide body kit. Needs finish work. All pieces are mounted and the filling and evening of gaps and edges has been started with professional grade filler. This is all the car needs body work and paint
Engine/drivetrain: 1uzfe v8 (non vvti). Runs perfect. K&N intake filter. 2.5" single exit exhaust w/burnt tip. Deleted resonators, brand new starter, Ran on Mobil 1 synthetic every 3000 miles while i have owned it. Replaced alternator and belts last year, 4.27 geared welded rear end, spare 4.27 open diff included as well as shorty headers for the v8
Transmission: automatic, car has been converted to 98+ gated shifter the correct way using factory plugs. Shift lock button is required to shift out of neutral into park for safety
Wheels: only 2 wheels included with tires 20x10 +20 boss 338s I have a set of 19x11 and 19x10 XXR 531s without tires and the 19x11s are still on back order slated to arrive this month that I will let go with the car at the $4000 asking price
Suspension/Chassi: Full CX racing adjustable coilovers newly installed never seen the road, new brakes all the way around rotors, front calipers and pads, rear subframe solid collars and differential bushings. I also have rear toe and traction arms not installed
Issues that annoy me: a small crack in drivers side door leather, ac needs a charge, it gets 22.8mpg highway and requires 93 octane, Nothing major at all is wrong with the car.
$4000
Please call or text 518.813.0247 if interested. No trades only cash excepted. Clean NYS title
