Well…there comes a time, when sacrifices have to be made. This is possibly the BIGGEST one i have ever had to make.
Car is paid for and lein release is in hand!
The car is pretty muc immaculate…with the exception of a few little things here and there…it is NOT a perfect car by any means, but its damn nice. I will provide more details to anyone SERIOUSLY interested.
I can tell you, this car has won over 20 awards in the car show scene, including 2nd place at the carlisle all ford nationals. The car rips down the track as well.
Currently it has just a bit over 42k miles on it. The motor has about 3k miles on it since being upgraded.
Car made 467rwhp and 432 rwtq on 13 psi…will need a re-tune since upgrading t/b, intake and smaller p2.9 pulley. car should make over 500 rwhp easily with new mods.
I am looking for somewhere int he $18k range with little flexibility.
Here is a brief rundown of SOME of the mods…not to mention all the interior and exterior mods to go with it…way to much to list now…more info for interested people…
Call me if interested. 716-444-1358 (Joe)
[LEFT]Bored 0.20 over [/LEFT]
Forged Cobra Crank
ModMax H-Beam Rods
Manley Platinum Series 18cc Dished Forged Pistons
Speed Pro Moly Ring Set
Federal Mogul Bearings
MMR HV Cryo’d Oil Pump w/ HV Pickup
Moroso 7 Qt Oil Pan
VT Stage 2 Blower Cams
Comp Cams Beehive Valve Springs
ARP Main Studs
ARP Rod Bolts
ARP Head Studs
Vortech V1 S-Trim Supercharger
3.12 S/C Pulley (Made 13 psi @ 6k RPM) <- pulley is gone, have a 2.9 RR pulley on it now)
MPH Power Pipe
P51 Intake manifold with N20 Burst Discs Installed.
SCT BA2400 Mass Air Meter
K&N Filter
75mm Accufab Throttle Body
EGR Delete
42# Injectors
Dual Cobra Fuel Pumps
Modified FPDM
Kenne Bell 40 amp Boost-A-Pump
B&M Short Throw Shifter
Centerforce Dual Friction Clutch
8 Bolt 11" Nodular Cobra Flywheel
BBK Long Tube Headers
BBK O/R H-Pipe
Borla Cat Back Exhaust
SCT Xcal2 Tune
Eibach Pro Kit Springs
Lakewood 70/30 Front Struts
CAM Caster Camber Plates
BBK Chrome Strut Tower Brace
PA Racing Tubular K-Member
BBK Full Length Sub Frame Connectors
UPR Clutch Quadrant & Firewall Adjuster (not installed yet)
DS Safety Loop
FRPP 3.73 Gears
[LEFT] Cross Drilled / Slotted Rotors w/Ceramic Pads
[/LEFT]
