posting this for a coworker…Please call if interested. i will not respond
Motor:
All parts have less than 2500 miles
-96 ls bottom end with new OEM color matched bearings and new OEM rings
-New timing belt, water pump, oil pump, and tensioner.
-New oil pan gasket, new coolant bypass seals, new head gasket.
-LS head that has been port and polished and gasket matched.
-, new arp head studs, titanium valve springs.
-New valve cover gasket and cam seals, upgraded cams with adjustable cam gears.
-330cc injectors with new injector seals, AEM high flow fuel rail with regulator.
=Victory x intake manifold with new manifold gasket, 70mm throttle body.
-Ebay Ram horn turbo exhaust manifold with external 8 PSI wastegate.
-Jdm sport T3/T4 turbo with front mount intercooler and blow off valve
-It does come with a boost controller but it’s not hooked up right now.
-Chipped and socketed p28 ecu tuned by ccc
-GSR transmission with a stage 3 6 puck clutch and fidanza lightened flywheel.
Interior:
Tan leather with tan interior
No rear seats or trunk plastics
-A pillar gauge pod with aem wide band o2, boost, and volt gauges, as well as water temp
Suspension:
-Front and rear upper strut bars, front camber kit, new rear lower control arms, as well as coilovers all around
-17" wheels, front traction bar system
Car has zero rust.Entire car painted honda sequoia green less than a year ago
Needs: rear brake line…possible retune and tires
Price $3000
call 951-9699
