i didn’t even receive this item yet, it is still in the mail. I’m considering going in a different direction. so i am gauging interest for a possible sale…
It is powdercoated black with poly ends.
i will bite the shipping, it wasn’t cheap
$125
<b>Panhard Bar - Tubular Adjustable with Poly Bushings</b>
Application: 1982-2002 GM F-Body
Replace the factory’s weak, stamped steel, flexible panhard bar with one of our heavy duty set-ups! Allows for centering the rearend after lowering. The best component for serious handling performance. Allows alignment of the rear for clearance when running larger tires. Greatly increases rear’s lateral stability.
Specifications:
- 1.25" x .095" wall mild steel tubing
- Stronger, yet lighter then stock
- Polyurethane bushings (fluted) with grease fittings for easy lubrication
- Right hand and left hand threaded CNC machined double male stud adjuster threads into 4130 chrome moly TIG welded threaded tube adapters
- Reuses OEM mounting hardware, no need to drill out your car’s mounting brackets
- This is the highest quality, easiest to adjust on the car panhard bar on the market!
- Available powder coated in your choice of the above colors
4130N Upgrade: The ultimate in bullet-proof lightweight strength, 100% TIG welded 4130N chrome moly construction! Same as above, but constructed entirely from 4130N chrome moly tubing.
Note: Please allow an additional 7-10 business days for shipment of colors other than red or black.
