Ok, up for grabs is a whole ca18det setup, i had the engine rebuilt, it spun a bearing ( its in teh car in my other post but im selling the car with a ka24 in it, ca18det seperate)I love this engine, and i want badly for it to run and turn out, but i just dont have the time and money for it anymore, its time to pass it on to somebody with more of that. I have school coming up for second year welding, and house to save for, so this has to go till later on.
It was completely rebuilt, and has the following
-Forged pistons, .40 over, brand new just installed total seal rings
-Completely redone head, new valve seals, reseated valves, everything jetwashed, and decked .04, completely flat
-Brand new head gasket
-Just installed newer sr20det turbo, shaft play is excellent.
- New timing belt.
-Cw transmission, has spec stage3 clutch, very good condition clutch, grabs hard.
-444cc gtiR injectors
-Ecu is chipped for injectors and rb20 maf (maf is included)
-comes with side mount and all associated piping, and a ARC PROF bov on the hot pipe.
theres more im prolly forgetting, but thats the rundown
Here the bad
Bearing spun, number 1 rod bearing im pretty sure. I origionally rebuilt the engine over the winter, ran great but i didnt clearance the rings correctly so i took it apart again, ordered new rings, and had a “professional” put it all back together. Drove it for a day without problems, then all the sudden it started knocking. Its definately a rod bearing, and 90% sure its #1.
This would be a great engine for somebody to buy and repair what i dont have the time or money to do right now. I will include a new crank that has just been polished, and a rod if it ate the rod, which i doubt it did…but if you purchase it from me and come back with the rod and its bad, i will give you another no questions asked. Bearings are sitting at brasso nissan and are 68$. It can be fixed for relatively cheap…i just dont care to do it.
asking 1000$ obo, pm if interested. Pulling it this weekend to replace with ka24de.
edit: If you can actually find a ca18det, importers charge 1500$ for one, barebone stock, with a shitty ca18det turbo that will guaranteed blow up in a week, and usually with a stock clutch.
im including a sr20 turbo and an awesome clutch…keep that in mind
Cheers
