Get infinitely adjustable timing, with Cloyes Hex-A-Just timing sets.
With Cloyes Hex-A-Just timing sets, infinitely adjustable cam timing is as simple as turning an Allen wrench. Consisting of SAE 1144 billet steel cam and crank sprockets and a True Roller timing chain, Cloyes Hex-A-Just timing sets use a special hex-head bushing installed on your cam’s dowel pin. This bushing lines up with degree marks on the cam sprocket. You can adjust timing in fractions of a degree (as much as plus or minus six degrees) by loosening the cam bolts and turning the bushing with an Allen wrench. Cloyes Hex-A-Just timing sets install under your stock timing cover and can be used in align-bored blocks.
i have a custom grind LSx cam
the cam is a 226/223 .57x/.57x" on a 115
good idle quality with subtle yet noticable “lope”
great power range, great ride quality
proven power
