I made the box myself and the covers were custom made by Audio obsessions.
Its a vented fiberglass enclosure w/ 2 10" MTX subs and 2 MTX amps. amps are rated at 200 Watts peak.
Its a low power system w/ alot of sound!
The box was designed to get the maximum performance out of these subs.
I believe it registered at 138db at a sound off.
It fits directly in your spare tire well and its bolted down using your spare tire bolt.
The covers are MDF and are vented above the subs, amps and the port of the box.
They are extreamly sturdy and you can basically still use your trunk space like you normally would.
now pictures
And if you have a rear strut bar like i did, you can still use that too!
Asking price is $300 for everything. box, covers, subs and amps.
pickup only
if you would like to see it in person, id be more than happy to show it.
Since the box and covers were designed for these subs and amps, im not parting it out.
and those of you with black or gray interiors, the covers can be re-carpeted by any custom audio shop fairly inexpencve. $50 max.
I know a few shops that would do great work if you dont know any.
Single tuned vent is next to the Left amp. and those parts that look black on the under sides of the covers, are mesh grilles. they vent through the carpet over the amps, subs and the port
Yea dude, i could build you one. it takes about 3 days to make the fiberglass part. The covers i had made by Audio obsessions
