For sale is a lightly used 2 Post vehicle lift from Direct Lift. This is a very nice unit that I had purchased about 1 and a half years ago and has been used in a light duty automotive setting. It is capable of lifting 9000 lbs and is good for most cars, trucks, and SUVs out there. It has the Truck height adapters for the lift arms as well as rubber lift pads. It is perfect for anyone with a touch less than 10’ of ceiling height because it stands roughly 9’3" tall and can lift your vehicles nearly 7’ up. Requires a minimum of 4" of concrete with 3000 psi. You can get nearly any height vehicle on this lift, just keep in mind there is a ~3" tall base plate. Please email me with an email titled appropriately so I know what you are asking for. I can supply more pictures if you’d like, or we can schedule a visit to take a look at it. It is still assembled and working so you can actually see it work before you buy.
$2,000
I can also include with the lift for an additional charge of $100 a nearly brand new transmission jack used 2 times.
Direct Lift Pro 9F Specifications
Capacity 9,000 LB.
Overall Height 111" (9’ 3")
Overall Floor Width 138 1/2" (11’ 6 1/2")
Outside Column to Outside Column 122" (10’ 2")
Maximum Lift Height 82" (6’ 10")
Minimum Pad Height 3 1/2" inches
Base Plate Width 15 3/4" inches
Inside Column 107" (8’ 11")
Drive Thru 97 1/4" (8’ 1 1/4")
Column Size 14 1/2" x 7 1/2"
Column Thickness of Steel 2 gauge (.24", 5mm)
Cable Diameter .375"
Base Of Lift (17 1/2" x 20 1/2" inches)
Motor/Electrical Requirement 2HP, 220 volt single (1) phase
A 30 amp breaker is recommended
