FS: Evo "Ingalls Stiffy" Engine Damper
No Longer Available.
Interesting, if you don’t mind me asking, what was the reasoning behind taking it off / experience using it?
[quote=“sureshot!,post:2,topic:40096"”]
Interesting, if you don’t mind me asking, what was the reasoning behind taking it off?
[/quote]
It does pass some noise/vibration into the car. I drive alottt for work and it was getting to me, guess I am just getting old. You could always put some dynamat under the bracket to help the vibration/sound. Its just been sitting around.
Jeller
Jeller - the vibration/noise obviously outweighed the benefits for you. How severe was the increase in vibration? I’ve been looking into snagging a damper for a while, but not if the car is extremely ridden with extra vibration/noise to the point where I want to pull my hair out…
If it’s not that bad, I may be interested in snagging this from you :tup:
[quote=“Geoff,post:4,topic:40096"”]
[/quote]
Its not that bad, its not like doing all the motor mounts with hard polys. Its more of a noise transfer than a vibration transfer. Since the damper bolts to the shock tower/brace and the other end is on the motormount/block there will for sure be some transfer of sound. Your call really…
Jeller
I have the stillway version of this and love it. the biggest difference I noticed was how much easier it was to shift gears under load.
hmm…
lowball offer of $50?
$75 but thanks for the offer.
Jeller
