FS: G60 corrado Brembo Blank Rotors NIB 11.0" 4x100
I bought these for a brake project but went another route
Brembo Blank G60 Corrado Rotors New in the Box asking $75.00 OBO
these are at synapse now & still available just ask morgan
Hm.
These typically have to be re-drilled in Honda applications correct?
whats your center bore on your hubs?, the VW is 57.1
hondas center bore is smaller. so they fit loose on the hub, but 4x100 is 4x100 no matter how you cut it
Fastbrakes has use this rotor in multiple brake upgrades including rear nsx calipers (which is what I will be running on the eg) he might have used hub rings, I am not sure tho.
no need to redrill
