Buy all three kits for $40
Energy Suspension
Part Number: 16.3104
Rear Lower Control Arm Bushings $25.00
Polyurethane Rear Control Arm Bushings
On the rear, these control arm bushings are a must for controlling wheel hop and increasing cornering control for competition uses as well as maintaining alignment on and off-road.
[B]Performance Polyurethane Rear Control Arm Bushings
- Maintains proper alignment under extreme conditions on and off -road and during competition.
- Improves vehicle handling, cornering and overall control.
- Full floating, for smoother operation.
Made of Energy’s HYPER-FLEX™ performance polyurethane to add performance and durabilityOne Kit Will Cover both sides of the vehicle[/B]
[LEFT][COLOR=black]Lower Only Control Arm Bushings Only[/COLOR][/LEFT]
[LEFT][COLOR=black]
[/COLOR][/LEFT]
[LEFT][COLOR=black]Manufacturer : Energy Suspension[/COLOR][/LEFT]
[COLOR=black]Part Number: 16.1102
Shifter Stabilizer Bushings Honda (D Series Engines) [COLOR=red]$10.00[/COLOR]
[B][FONT=Arial]Polyurethane Shifter Stabilizer Bushings
[/FONT]
[COLOR=#cc0000][FONT=Arial]By using performance bushings, you’ll take the slop out of your shifting mechanism and you’ll be able to make faster, more consistent shifts. These new shift stabilizer systems are made of long lasting, firmer polyurethane. These bushings handle the stresses put on the vehicle for high performance driving, as well as all out racing.
[B]Performance Polyurethane Shifter Stabilizer Bushings
- [I]Replaces distorted and worn-out original rubber bushings–better than new!
- Maintains consistent shifts - even in harsh racing environments
- Allows the shifter to interact with the transmission in proper alignment - resulting in a crisper, more precise shift every time.
Made of Energy’s HYPER-FLEX™ performance polyurethane to add performance and durability.[/B][/I]
Part Number: 16.8103
[I]Rear Shock Mount Bushings [COLOR=red]$25.00[/COLOR][/I]
[B]Polyurethane Rear Shock Mount Bushings
[COLOR=#cc0000][FONT=Arial][COLOR=#cc0000]They give any vehicle’s suspension instant response and control using increased durometer (firmness) material settings. Give any shock absorber maximum efficiency while extending its life![/COLOR]
[/FONT]
[FONT=Arial]Polyurethane Rear Shock Mount Bushings
- [I]Adds performance to any shock!
- Benefit from better durability over O.E.M. rubber bushings.
- Important to use for competition of any kind.
- Made of Energy’s HYPER-FLEX™ performance polyurethane to add performance and durability.[/I]
[/FONT][/COLOR][/B][/FONT][/COLOR][/B][/COLOR]
