LS block just bored and honed (bore 81.25mm) was done at station still has the tag on it…to go with it i have the original crank that was micropolished at the same time at station and check out good was not cut just magged and ls rods honed for arp rod bolts that are in them and machined small end for type r pistons (itr or ctr) $200 for all…there is that much in machine work costs
jdm b16 block with crank, came from a jdm swap i bought and was never used less than 40k on them so perfect for a rebuild can’t find the pistons and rods though $100
stock b16 header $25
9mm arp rod bolts brand new $50
ls block that needs resleeved $50
pm or text/call 724 809 5480
Wray
