FS: Parts/lots of stuff Updated July 20th
do you still have any of the car dollys
resistance1630 - I still have all the car dollys.
psi2high - I have some used flywheel bolts.
01AudiS4 - Those numbers are about 15 horse higher than for a 6cyl.
List has been updated.
how much for the flywheelbolts?
did you get my pm’s?
Estorvito- I replied.
psi2high- How does $10 sound?
sounds good let me know i can paypal money…thanks
the fuel pressure regulator and fuel rail outlet adaptor are sold to me.
by any chance you have a stock shift knob? mine seemed to have disappeared and i liked it, lol so if you have one of those too please let me know.
im also still extremely interested in the rims/tires but obviously im gonna need to get the gas tank stuff first, but ill let you know asap on when i can get the rims.
thanks
-Steve
FS list has been gone through…some prices changed…some things were added…some things were sold.
Universal parts
Greddy Spec2 ProfecB silver (used) $200 or B/O
HKS Boost control solenoid box (used) B/O
Razo Carbon Fiber Shift Knob (used) $25
K&N Air filter 3.25" id for tube (hieght1_5.5"x hieght2_4.5"x 8" long, used) $50
Aeromotive AFPR #13109 with fittings, -6ss line (used)$100 (3 people are interested in this…it all comes down to who pays first.)
Aeromotive A1000 Fuel Pump has never seen fittings or gas $275
HKS SSQV BOV with adaptor for 2g/evo and block off plug for intake (used)$100
Walbro 255hp (used)$60
Walbro 255 (used)$50
Walbro 255 (new)$65
DSM
2g stock center vent B/O
2g stock cluster trim B/O
2g big K&N filter kit with new filter $65
2x 2g maf (these do not have honeycombs and will need tuning software to install) $25 each
2x 2g maf connectors with 4inch leads. $5 each
2g o2 housing $50
2g exhaust manifold(ported to 7cm) $75
1g Dejon CIP-1gA 2.5 intake elbow for stock mas $25
2x 1g complete 3bolt lsd rear ends $150 each
1g 3bolt diff only non-lsd $50
3x DSM 450cc injector sets(4 injectors per set) $50 per set
2x DSM Resistor packs w/ weather tight connector $40 each ($100 Package deal with a set of 450cc injectors)
2x 1g n/t 2.0L ecus (1x 90 and 1x 91) B/O
2x 1g primary rad fan B/O
2x 1g A/C fan B/O
6x 1g rear 6x9 speaker brackets B/O
1x 1g flipup headlight assembly with 2 motors B/O
1x 1g alternators(tested perfect @ Autozone) B/O
1x 1g 91+ Non-turbo throttle bodies $50 each
2x 1g 91+ CAS (w/tin backing) $50 each
5x 1g stock side mount intercoolers $40 each
1g non-cruise t.b. cable $20
1g Dejon (only one ever made) 4" intake pipe w/filter (turbo in stock location, puts filter in side mount intercooler area) $200
2x 1g Cyclone intake manifolds both work $50 each
5x 1g stock intake manifolds $25 each
1g stock intake acordian hose B/O
2x valve covers no cracks $50 each
1g exhaust manifold (no cracks and ported to 7cm) B/O
2x 14b stock compressor outlet pipes B/O
2x 1g Bov $35
2x 1g bov pipe with flange B/O
1g 90 fwd turbo 5spd trans $150
1g 91 fwd turbo 5spd trans needs rebuild $75
complete 14b turbo with o2 housing partial oil drain line $100
14b turbine housing with slight crack B/O
1g turbo stock t.b. inlet B/O
1g full a-pillar pod dual gauge used $25
1g Dejon Big Side mount intercooler (used, with custom aluminum duct) $300
1g Dejon Upper and lower intercooler piping for side mount intercooler (used) $150
Magnacore plug wires(used) $35
SBR fuel rail outlet adaptor to -6an $15
NOLOGY red plug wires used $40
1g Turbo fwd flywheel $40
1g or 2g/fwd or awd turbo clutch slowboyracing 3500 clutch used $50 or B/O
Misc
4x Car mover dollies $75
are you going to be there this sat? give me a call.
Universal parts
K&N Air filter 3.25" id for tube (height1_5.5"x height2_4.5"x 8" long, used) $50
Walbro 255 (new)$65
Stewart Warner oil pressure gauge 52mm (black face, silver trim) used $35
Stewart Warner fuel pressure gauge 52mm (black face, silver trim) used $35
DSM
2g o2 housing $50
2x DSM 450cc injector sets(4 injectors per set) $50 per set
2x DSM Resistor packs w/ weather tight connector $40 each ($75 Package deal with a set of 450cc injectors)
2x 1g A/C fan B/O
2x 1g Bov $35
1g Dejon Upper and lower intercooler piping for side mount intercooler (used) $100
Misc
I mistyped the package deal but it is corrected now.
Updated page 1 with new pricing and more parts!
Updated and bump.
