Hey guys some plans have changed and summer is approaching so maybe someone out there is looking for a nicely built motor that I have been working on all winter…
Here is a list of things done to the motor and things that will be coming with it…
S14 SR20DET (After Minor Change I’m Told)
Build has about 500 KM’s On It Pretty Much Brand New
CP Pistons 87mm (1mm Overbore)
Eagle Rods
CP Piston Rings
ACL Race Bearings
Earl’s Stainless Steel Braided Turbo Lines
Aeroquip Fittings
ARP Rod Caps
ARP Main Studs
ARP Head Studs
S14 SR20DET OEM Gasket Rebuild Kit
Cometic Metal Head Gasket
NISMO Thermostat
Tomei Rocker Arm Stoppers
Tomei Tuned ECU
HKS Intake
SARD R2D2 BOV
History of the motor…
When I had got this motor it was running well then it started blowing smoke and I found out one of the pistons were bad so I thought well it sure is time for a build. I ordered all the parts listed above brand new and I think I still have receipts lying around. The engine work was done at Alberta Engine Rebuilders and then assembled by Sumaru’s Auto. As I said the motor has only about 500km’s since the build on it.
The motor is currently in my car now and can be seen running and taken for a test spin to serious buyers only!
Asking Price Is $5000.00 OBO!
Very flexable on the price right now as I need the cash for other projects and junk.
Located in Edmonton!
Add me to msn at sil80_rs13 at hotmail.com
or call me at 780 885 8674 for faster response as I’m usually really busy.
