And Bump
-All Clevite bearings (Mains, cranks, and thrusts) - $100
will these work on an s13 redtop sr?
Thats what they are for, yes. These bearings aren’t color coded. Some oversized oned from Nissan ARE. So provided your crankshaft has NEVER been grinded, and is in good shape (can determine with a few quick measurements on each journal) these will work no problem. All the parts listed above are for the S13 Redtop SR20.
HKS rocker arm stoppers SOLD!
Here’s the list on whats left… With NEW prices!
86.5mm CP pistons 9.0:1 compression - $600
-Crower titanium rods - $600
-ARP main studs - $80
-cometic headgasket - $100
-All ferrea head parts (dual springs, retainers, keepers, 1mm oversized intake and exhaust valves) - $800
-HKS 272 Step 2 camshafts (12.5mm lift, BIG cams) - $380
-Jim wolf adjustable cam sprockets - $120
-Jim wolf valve guides - $140
-Greddy intake manifold - $540
-Brand new nissan valve guides and timing chain and timing chain oil jet - $250
-ARP head studs - $70
Bump
Just offering something! (within reason) I need a truck!
Bump
give me a price for all this stuff for a good deal ill pick it all up
Ferrea locators, retainers, springs, and keepers SOLD! Only Ferrea parts left are the 1mm oversized intake and exhaust valves.
ARP headstuds SOLD!
Bump
Still for sale! Make an offer on stuff! Work is getting busy and I need this gone!
Well man, how bad you wanna get rid of that intake mani? Let me know your bottom line and maybe we shall meet up again, haha.
Chris
yea man how low are u on the intake mani anways
The body has been SOLD!
All STOCK SR20 parts SOLD!
-86.5mm CP pistons 9.0:1 compression
-SR20 block cleaned, bored, measured, and balanced
-Stock SR20 head (needs machining for valves and cleaning too)
-ARP main studs
-cometic headgasket
-All ferrea head parts (1mm oversized intake and exhaust valves)
-Whiteline swaybars (front and rear)
-JIC Magic tension rods
-Stock 89 240SX BRAND NEW NEVER USED heater core, 2 front outer tie rod ends, 2 front wheel bearings, and 1 right engine mount.
-Energy suspension master bushing kit (some bushings gone such as front control arm and rear subframe)
All for $3000. Just to clear it out of here. That with the tranny kit included! If you bought it seperatly, it’d be $2000! You can’t go wrong and you can’t do better then this!
pm me wit your number…i have bout 2000 g to spend
