So I’m cleaning out the stuff I own since i no longer need any of it. Most of these things I collected but never used. Everything works. All I want is what I paid for them, so most of these prices are pretty firm but I’ll entertain all reasonable offers:
MSD DIS-4 IGNITION SYSTEM $300 Also have adapter plates to fit GM 3100, 3400 & 3800 Series engines & MSD GM Twin Tower Coil Packs w/ 10.4mm wires for $75 additional
GREDDY TURBO TIMER $50
AUTOMETER 10K TACH W/SHIFTLIGHT & TACH ADAPTER $100 Adapter was $100 alone. It converts AC to DC or vice versa I cant remember which. It was necessary for me to get an accurate reading from the RB20 ECU
APEX-i NEO AFC $250 Comes with booklet.
INFINITI Q45 MAF $65 Comes with Pigtail
GRIFFIN ALUMINUM RB RADIATOR $200 Paid $419 New. Used for less than 800 miles. Will not work with SR20 without a different upper radiator hose but should work with stock KA and all RB’s
Z32 BRAKE MASTER CYLINDER $50
S14 E-BRAKE HANDLE/CABLE $65 I had S14 rear spindles on my 91 coupe and bought this so I had an ebrake but never installed it because I just swapped the S13 calipers onto the brackets and used the OEM cables instead
1987 CA20SE MAF $110 1986-89 Nissan Stanza, Axxess, 200SX Bought this as a Reman’d unit for my 87 Stanza, never installed.
