fuel mapping
need to find stock s13 sr20det redtop fuel mapping
You can google sr20det bin and you’ll probably find a base map. I use romeditor and live edit to view maps… I think with rom editor you can export the fuel map to excel.
if you have the consult plug I can download the bin or show you the realtime map.
Only issue with using the stock bin is that the fueling map does not work the same way a standalone map does. In the stock bin a value of 128 means 14.7 or more accurately the ecu will try to accomplish 14.7 through oxygen sensor feed back.
If you use nistune you can convert the raw values into duty cycle but once again that is just a calculation.
running greddy emanage ultimate
