Rom editor for sr20 help
Hey, so ive been messing around with rom editor, mostly because i want to learn to tune myself. So i uploaded the adr file and bin file that i found off the net for a s13black top with z32maf and 550cc injectors. my quesiton is how do i read the values on this program? i know to use only the hi octane fuel map and hi octane ign map but the numbers on there see mto far off…like on the x axis it goes 0 +1 +2 +3 + 4+5+6+7+8+9+a+b+c+d+e what does htis mean exactly?:S and the same goes iwth the y axis 0130 0140 etc. if anyone has found any good writeups on this program or have experience using it maybe you could shed some light on it? i’ve searched the net and can’t find any in detail write ups, thanks!
willing to part out your motor after it blows up?
well gotta learn somehow, trial and error. thanks for your useless input.
The x axis represent your engine rpm and the y axis represent your tp or load. It will take you a life time to reverse engineer those codes so stick with the basic like rev limit or speed limit first. One wrong code will really can cost you an engine so have fun.
