So I took the car for a spin (30-40min) drive and began logging some
numbers from start up to shut down.
I’m still reading up on what optimal/good values are but if anyone’s
curious, here’s some min/max data values.
PM if you are interested in the entire log as an Excel file (about 650KB zip)
Stock setup, 91 octane, +5C outside temp., 8psi max.
MIN. RPM MAX. RPM
RPM : 812 RPM : 5775
Air_Flow : 1.58 Air_Flow : 4.66
Water_Temp_C : 77 Water_Temp_C : 78
O2_Sensor : 16 O2_Sensor : 92
Speed_kph : 6 Speed_kph : 38
Battery : 14 Battery : 13.9
Throttle : 0.46 Throttle : 1.68
Injector : 2.27 Injector : 16.19
Timing : 15 Timing : 18
AAC : 12 AAC : 75
A_F_Base : 96 A_F_Base : 100
Duty_Cycle : 1.54 Duty_Cycle : 77.91
MIN. AIR FLOW MAX. AIR FLOW
RPM : 2300 RPM : 1188
Air_Flow : 1.45 Air_Flow : 25.62
Water_Temp_C : 81 Water_Temp_C : 83
O2_Sensor : 27 O2_Sensor : 64
Speed_kph : 66 Speed_kph : 0
Battery : 14 Battery : 13.8
Throttle : 0.46 Throttle : 1.8
Injector : 0.58 Injector : 61.45
Timing : 1 Timing : 15
AAC : 47 AAC : 50
A_F_Base : 100 A_F_Base : 79
Duty_Cycle : 1.11 Duty_Cycle : 60.84
MIN. TEMP MAX. TEMP
RPM : 1038 RPM : 4012
Air_Flow : 1.6 Air_Flow : 1.91
Water_Temp_C : 58 Water_Temp_C : 83
O2_Sensor : 81 O2_Sensor : 2
Speed_kph : 0 Speed_kph : 118
Battery : 14.2 Battery : 13.9
Throttle : 0.46 Throttle : 0.46
Injector : 2.26 Injector : 0.58
Timing : 9 Timing : 15
AAC : 8 AAC : 60
A_F_Base : 117 A_F_Base : 100
Duty_Cycle : 1.95 Duty_Cycle : 1.94
MIN. O2 SENSOR MAX. O2 SENSOR
RPM : 1350 RPM : 5538
Air_Flow : 1.58 Air_Flow : 4.46
Water_Temp_C : 73 Water_Temp_C : 81
O2_Sensor : 0 O2_Sensor : 98
Speed_kph : 0 Speed_kph : 114
Battery : 14.1 Battery : 13.8
Throttle : 0.48 Throttle : 1.02
Injector : 1.89 Injector : 14.06
Timing : 12 Timing : 19
AAC : 22 AAC : 75
A_F_Base : 100 A_F_Base : 100
Duty_Cycle : 2.13 Duty_Cycle : 64.89
MIN. SPEED MAX. SPEED
RPM : 1038 RPM : 4538
Air_Flow : 1.6 Air_Flow : 2.74
Water_Temp_C : 58 Water_Temp_C : 82
O2_Sensor : 81 O2_Sensor : 85
Speed_kph : 0 Speed_kph : 128
Injector : 2.26 Injector : 3.68
Timing : 9 Timing : 30
AAC : 8 AAC : 75
Duty_Cycle : 1.95 Duty_Cycle : 13.92
MIN. THROTTLE MAX. THROTTLE
RPM : 4588 RPM : 3538
Air_Flow : 2.39 Air_Flow : 4.1
Water_Temp_C : 81 Water_Temp_C : 78
O2_Sensor : 73 O2_Sensor : 89
Speed_kph : 100 Speed_kph : 48
Battery : 14 Battery : 14
Throttle : 0.44 Throttle : 4
Injector : 0.58 Injector : 14.82
Timing : 15 Timing : 3
AAC : 75 AAC : 38
Duty_Cycle : 2.22 Duty_Cycle : 43.69
MIN. TIMING MAX. TIMING
RPM : 2225 RPM : 1912
Air_Flow : 1.84 Air_Flow : 1.68
Water_Temp_C : 60 Water_Temp_C : 81
O2_Sensor : 46 O2_Sensor : 56
Speed_kph : 0 Speed_kph : 2
Battery : 14.2 Battery : 13.7
Throttle : 0.48 Throttle : 0.5
Injector : 0.57 Injector : 1.54
Timing : 0 Timing : 37
AAC : 25 AAC : 31
A_F_Base : 100 A_F_Base : 98
Duty_Cycle : 1.06 Duty_Cycle : 2.45
MIN. A/F BASE MAX. A/F BASE
RPM : 2275 RPM : 962
Air_Flow : 3 Air_Flow : 1.6
Water_Temp_C : 80 Water_Temp_C : 63
O2_Sensor : 46 O2_Sensor : 30
Speed_kph : 32 Speed_kph : 0
Battery : 14 Battery : 14.2
Throttle : 1.38 Throttle : 0.48
Injector : 6.63 Injector : 2.41
Timing : 23 Timing : 9
AAC : 25 AAC : 8
A_F_Base : 79 A_F_Base : 118
Duty_Cycle : 12.57 Duty_Cycle : 1.93
MIN. AAC MAX. AAC
RPM : 1038 RPM : 4650
Air_Flow : 1.6 Air_Flow : 4.4
Water_Temp_C : 58 Water_Temp_C : 78
O2_Sensor : 81 O2_Sensor : 90
Speed_kph : 0 Speed_kph : 24
Throttle : 0.46 Throttle : 2.46
Injector : 2.26 Injector : 15.61
Timing : 9 Timing : 13
AAC : 8 AAC : 75
Duty_Cycle : 1.95 Duty_Cycle : 60.49
MIN. DUTY CYCLE MAX. DUTY CYCLE
RPM : 1175 RPM : 5575
Air_Flow : 1.64 Air_Flow : 4.7
Water_Temp_C : 80 Water_Temp_C : 81
O2_Sensor : 0 O2_Sensor : 96
Speed_kph : 34 Speed_kph : 114
Throttle : 0.48 Throttle : 2.66
Injector : 0.58 Injector : 17.14
Timing : 0 Timing : 17
AAC : 22 AAC : 75
Duty_Cycle : 0.57 Duty_Cycle : 79.63
