FUEL pump relay??
Ohk, engine cranks , but fuel pump is not coming on?? we tried manually priming it, fuel pump works, can anyone tell me where the relay is(egi pump i think?) so close to starting it but this little issue is the only obstacle dunno, if anyone could tell me the location of the relay would b great.
thnx!
In the fuse box by the battery .
tnx Nis, fixed that problem, now the car wont start, i’ll just read heavythr. over again, gah, my shop sucks, close too early :roll:
Are you getting fuel pressure at all?
kno what, fuel pump works manually, but when ignition is turned on, nothing, the whining noise isnt there and when i crank it, no fuel is pumping to the engine. dunno, relay seems ok, dunno what else, just gas is not going to the engine at all, engine cranks tho.
any suggestions guys?
crappy wiring or the harness? bad ground wire?
