garret t3/t04e turbo oil restrictor
well my car puffs some smoke after i get on it now i was reading that theses turbos should have a restrictor if over 60psi oil pressure. my pressure at full throttle is around 80psi. so im thinking there maybe be some oil coming threw my turbo and burning up in the exhaust causing the smoke. has anyone had this happen or heard of it happening, also are there diff size restictors or are they the same. and can anyone verify the oil pressure numbers for the turbo thanks in advance.
alot of questions in there sry but ne help would be great.
You should have one as should I with a warm up oil PSI of 70.
I heard turbo seals do not like to see above 25-30 psi.
atpturbo.com carries them.
:wstupid:
yeah, i third that
he’s not BB tho.
BB turbos need less oil pressure.
I have restrictors in stock, but they’re generally only necessary on BB cartridges as Newman said.
