Anyone know the mechanical and performance differences between the GM LQ4-U 6.0 liter and the LQ9-N 6.0 liter motors?
im sure brian does
compression is higher on the lq9
LQ9 has flat top pistons which makes for 10.1 CR also has stronger internals
LQ4 has a dished piston which allows for 9.4 or 9.5 CR depending on the type of heads [iron/alum]
stock for stock LQ9 better NA motor but ppl do boost them
LQ4 is good building block for a boosted application with its lower CR
Thanks for the info everyone!
seriously…you mods should make a forum called “ask quick”
hahahahaha, i know this one cause i have a LQ9
you should hear him talk. diarreah of the mouth and it will make you wish you were deaf.:blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah:
:love:
:love: ![]()
luckily i have an off switch on my hearing aid:D:
