Hey everyone. With the help of a from from the DSM board and some reading I came across these products that look to have some promis to them.
#1) Wideband O2 setup (http://www.14point7.com/JAW/JAW.htm)
Uses the inexpensive Bosch LSU Wideband Sensor.
Accuracy to 0.01 Lambda.
2 programmable outputs
Free Air Calibration
Real-time datalogging
User selectable refresh rate of 8-255 [hz] for digital display
Reads from 0.69 [Lambda] to 2.33 [Lambda]
Reads from 10.18 [AFR] - 34.28 [AFR]
$45 DIY Kit: Without Display
$70 DIY Kit: With Display
$60 Assembled: Without Display
$90 Assembled: With Display
#2)ABC: Another Boost Controller (http://www.14point7.com/ABC/ABC.htm)
$99 USD
30 day money back guarantee.
Uses the inexpensive GM typhoon Boost Solenoid (~$20 USD).
Firmware upgradeable.
Uses PID (Proportional Integral Derivative) control algorithm for tight and accurate Boost control
Realtime Data-logging of RPM + 5 external channels.
8 ft Connector cable included.
Boost Solenoid not included.
#3)Pro Sport Guages (http://www.prosportgauges.com/premium.php)
- Fully electric gauges
- Using remotely located sensors in the engine bay
- Peak setting and recall
- Warning with color change to amber
- No controller required
- Sensors included with most gauges
 The most exspensive gauge is still less then 100 USD (less for use due the the doller)
Remember you get what you pay for but, these seem to be solid lower cost items that will give you near the same functionality with a little more research and work on your part.
Let me know what you guys think?
