My groundwire kit just arrived this morning so ill be replacing them this afternoon. First thing i need is some sort of diagram showing where all the grounds are located(if thats available as ive searched son, zilvia, nico and google). If its not available i just need some general direction as to where they are, and so far i know of 2. Secondly the kit is one of those 7 to 1 kits and has a massive clamp on the back, where the hell does that go? Any help is greatly appreciated.
This is how i did mine… according to the instructions that came with my set.
Hope it helps.
thanks. now the kit has one of those big clamps for the negative battery terminal. Where do i put the negative battery wire after the clamp is on, or is it not needed and or do i chop off the clamp, but a clamp similar to the ones on the grounding kit, and attach it to the grounding kit plate?
