anyone instal one? i have a one and it has no instructions, should be straight forward but i can’t figure it out :grrr any help would be great
Yeah, I installed an Apexi SuperGround setup on my car.
You want to run a wire to the positive battery terminal, the alternator, and a body ground at a minimum. I can’t remember the other connection I have, but I can look at it tomorrow and see what I did.
I heard it was all the body grounds you could find and one engine mount min. But i never understood it… heh…
This might help
http://forums.thevboard.com/viewtopic.php?t=28695
there is some Picts towards the bottom 8)
thanks alot, but mine is one of those hks universal ones, it has the circle mount that you attack to the negative battery terminal, can’t figure out how that attackes or goes together
how many lines do you have? Cuz after reading the V’s solutions…
- Negative Post(Main Circle)
- One to body ground (aim for the driver fender)
- One to the altnator assembly (aim for the 13mm?? bolt that that is connected to the tensioner arm)
- One to the engine (dont know where…)
- One to the cover on the MAF sensor holding (Golden color shroud)
- One to the Intake Manifold (if you can find a spot)
Then again, check with others who have the setup, but thats how i’d do it… but of course I might be wrong… Someone correct me if i am… :rolleyes:
I think you mean Negative, at least mine was, perhaps that Apex’i needs power to it? But it should be the negative terminal.
Oh yeah, I guess so. The Apex has a voltage stabilizer unit included…I forgot about that part.
there is about 6 or 7 wires, that have to attach to a main circle hub sort of deal, then attach to the frame, alternater, block, head, and a couple more things can’t remember.
What is the name of the manufacturer?
supposedly hks, thats the sticker on it, but i already went to the website and found nothing
Look for the HKS Circle Earth grounding system. That’s what it’s called.
ok thank you
mine looks a little different then the ones they are showing, but pretty much the same idea, the only thing is that some of the pieces are different and i am not sure how to connect them
It’s an eBay knockoff, so you know. :roll:
that pisses me off, i bought it from josh, he said it was real, alright well then, now i know not to trust everything you hear.
i called josh, it is not an ebay knock off
Does it look anything like the one on the HKS site? :roll: How much did you pay?
yes it does, i payed like 120 or something
Same. Prepare to get flamed. :rolleyes:
