grounding question.
What grounds run of the neg terminal? Just the body and the intake manifold right?, where would the engine block, the head , and the cylinder head grounds be located. Are the last 4 i just listed body grounds or are they off of the battery? thanks
IIRC the only things directly connected to the batteries (-) terminal are the starter and the engine block. Everything else is ground through there.
Battery Terminal —> Chassis —> Engine Block
The Starter, Injectors, Spark Plugs etc. get their ground
through the Engine Block Ground. The Headlights, Stereo,
Brake Lights etc. get their ground through the chassis.
:stupid:
there is a ground to head on the fire wall on driver side too.
:stupid:
there is a ground to head on the fire wall on driver side too.[/quote]
But 95% of 240sx’s I have sceen have them broken or rusted off…
