Ok. So my stock turbo (t25 retop sr) is boinked. I ordered a gt2871r and Taka lines from Bing. I figured I would upgrade now rather than getting a stock repacement and having to do it later but I don’t have any upgraded injectors or z32 mafs just a upgraded manifold, full 3" exhaust wlbro 255 fuel pump. So my question is, will I have any trouble running this turbo at STOCK boost levels until I upgrade everything else?
that being said i did a drift day with my HKS GT-RS with 370cc injectors a while back and there was no problem, then again i was letting off whenever it creeped above 9psi
Hey Thanks guys. Bing I guess I should buy those injectors
Now then, I’m buying G’s power FC, and was wondering about cold starts and cold weather. I drive my car year round and have read about problems with the cold. Any thoughts
Im running on a GTiR T28 and running @ 9psi… My Injector duty is 98.7% and my MAFS reading is 4.92V. Meaning the Injectors are running static and if the boost got any higher the MAFS would fry as they max out @ 5V.
Luckly for me thou I dont get any boost creep.
But in other words… If anyone plans on going bigger then their T25 (you need Injectors/MAFS regardless) or their is no point in doing it.
