… T25-30, 1/2 the price of the HKS with more power.
uses a T25-( T28 non or BB avaiable ) with a 300Z super 60 Hi-po ( Nissans custom housing and compressor AR for fast flow ) Thier isn’t a turbo out there that can touch it for under 2x the cost. if your on a CA18 then a t25 turbine side would be the way to go…
Another option is a striaght T03 with a GTP trim 1/3 the cost of a HKS with only minor mods to the header flange and DP flange, make more power, at a lower RPM with a lighter rotating assembly.
BB is only 8% faster once the wet bering from a normal T series is broken in. However wet bering can be rebuilt with a $80kit, BB is a throw away core. Just a few things to be aware of… I can get both easily so it’s not a bias on my part… just a design chioce.
Lets be honest here. You buy a brand new turbo which is good for 100,000km at LEAST well maintained.
there is no reason the turbo will need a rebuild and the amount of people on this board that will have the same turbo setup for 100,000km is probobly 1 of every 300. We go through cars and motors like its our job.
I wouldn’t worry about thinking about rebuilding a turbo when you’re buying one brand new, just take care of it. If it gets hot let it cool down, always change your oil, you know the basic stuff.
