-would a EG half size radiator fit in a EF?
-will a B18c1 flywheel work on a B18a1 with a a1 clutch?
-will a B18c1 starter work on a B16 transmission?
-Also what is the compression ratio on a B18a1 and is it safe to run 12lbs of boost?
any b-series starter will fit even the auto ones … the rad i think should go right in if not a lil mod or two to get it to fit … flywheel i have no idea… boost you should run like 8-10 … w/ 110k on a motor … do you need a wastegate?? i have a extra
