on my S13 one light stays up and one wont… when one goes up the other goes down they both work but cant get them both up at the same time haha… any suggestions would be a big help
I had the same problem. Disconnect the battery, remove the caps for the headlight motors and turn them manually by hand until they are both down or up. I turned them till they were closed. reconnect the battery and see if that works. It did for me. GL.
Sick… Lazy Eye Conversion…
do what that guy said, it should work regardless, worked on my beater.
