pretty much the problem is that when i turn the knob to turn up the fan on the heat/ac, it doesnt turn on. Fuses are all good. Getting some kind of voltage coming from the wires on the switch and they do change when the knob is turned, but its not much voltage. when i press the buttons to change which vents to use, i can hear it swap the vents.
you shouldn’t have to rip the dash apart to replace the fan motor. A trip to M+M to get a fan motor and about a half hour under the passenger side dash. That should be all it will take. Good luck
you should see my 98 civic. I have the whole dash, seats, wiring, and motor off the damn shit. Im hoping to put everything back this weekend.
The fan motor is not that hard to take off,. I think all you have to do is remove the glove box and a couple 10mm bolts and wuala…
its in the fuse panel thats under the dash on the driver side. u will see a bunch of relays. the heat/ac fan is in the row closest to the fuses, so the bottom row of relays, and is right in the middle.
