last night I was playing battlefield 3 and my computer freezes, I turn it off and it wont start up not.
I get an error when it tries to boot from the hard drive saying
Disk boot failure, Insert system disk and press enter
so I put in the disk and it boots up into windows installation. I hit repair computer, let it try to repair it automatically because it says there is a problem with my computers startup options. but tells me that it cant. The error that shows when I hit details is
Problem Event Name: StartupRepairOffline
Problem Signature 01: 6.1.7600.16385
Problem Signature 02: 6.1.7600.16385
Problem Signature 03: unknown
Problem Signature 04: -1
Problem Signature 05: ExternalMedia
Problem Signature 06: 1
Problem Signature 07: NoOsInstalled
the last line is very odd because there is definitely an OS installed. I can even navigate the hard drive to look for drivers
so then I try to just install it because I want to see if the hard drives are recognized and they both show up but when I try to pick the one I have windows installed on it says
windows cannot be installed on disk. computers hardware may not support booting to this disk, ensure disk’s controller is enabled in bios
So I got into the bios go to hard disk boot priority but none are listed and the only option I have is
Bootable add-in cards
At this point I dont know what to do or what the problem even is, the hard drives are working since I can navigate them like I said and they are recognized by the windows installation.
how do I tell if its the main partition? after doing DIR it says
Volume in device X is boot
then lists all directories and found 74 files, 6 directories. seems that there should be more files than that but im not sure, never done this before
X is the recovery partition, you’ll need to Change drives. a CD C: assuming C: is the main drive will change to the C drive, so the Command prompt should read C:>. Then do the DIR command and look for your program files folder to verify that is your main partition. Like i said it could be any drive letter so you might have to change drives using the CD command a few times.
Although I don’t think the System File Checker works off the recovery partition. If you do that command and it complains that the machine is waiting on a reboot, it won’t work.
So is the consensus that its a windows problem? If thats the case im just going to go out and buy a SSD from BestBuy and install windows on that since I eventually wanted to do that
I usually boot to a copy of spinrite. That will tell you really quick if the drive has problems. It will take a week or so to try to fix them, but if it has a lot of bad sectors I just get rid of the drive and replace it.
Sounds like the drive overheated at first and failed, but from what I’m reading windows got corrupt. So this is my theory, you were gaming drive overheated computer restarted and got corrupt.
