while I was removing my cams on my redtop and I completely forgot that I had to keep order on my cam caps
I have seperate bags for exhaust side and intake side but not the order in wich they go
i’ve looked everywhere for the right order or a way on how to do it but found nothing…
I have only done a cam change on a S14. The caps on it were numbered. I would expect that yours would too. Then find the S14 FSM and follow the torquing procedure. It is important that you get everything lined up correctly and in the right order.
like dteam said they should have numbers if they dont then you should be able to pretty much figure out which goes where… put it on once its all theway down see if it lines upstraight and if it doesnt then it doesnt go there…
