for some reason i cant post under group buy so im doing it here.
H.I.Ds Stable Quality
the same manufacture as GM,Philip and Osram, reliable quality.
1 Year Warranty on Bulbs and Ballast
no need to ship, straight in house exchange
Regular Ballast Hid Group buy
10 people (any car) $105.00 with warranty
Single order is $120
Digital Slim Ballast
10 people (anycar) $135 with warranty
Single Order is $150
H4 Bulbs are High and Low beams.
this HID is 50% energy saving!
A 35W HID, up to 3~4 x the lumens at the source compared to a 55W halogen bulbs and longer projection distance.
Color that is closer to natural sunlight making it safer and clearer at night.
5 times longer life span than that of the conventional light.
Capsule aligned to the original bulb filament, and the original beam pattern is not altered.
Exact size and fitting to your OEM halogen bulb. 100% Reversible.
5" silicone coated wires with Silicone rubber grommet for an additional seal.
AMP waterproof sealed connectors.
Fully sealed. Full function DC 12V (9-16 volts).
World Smallest size (2.75" x 2.75" x 1.25") & weather resistant Ballast.
Silicone sealed wiring harness Precision manufacturing ensures straight vertical alignment.
Exact size and fitting to your OEM power source. Polarity insensitive, therefore you can not “fry” the Ballast. Full-proof positive (+) & negative (-) specific connection.
Highest German Industry Standard OEM quality HID Bulb, UV cut class with AMP sealed protection system, up to 3000 hours.
Comes with everything you need to make the conversion for your car.
Tech details:
ISO 9001:2000,E-Mark
Input: DC 9V-16V
Normal Working Voltage: 12V
Ballast Output Power: 35W
Life-Expectancy: >3000 hours
Working Temperature: -40’C-105’C
