high/low impedance injectors advice
whats ur setup?
The injectors are top feed and this is going on a KA24DE.
is it turbo’d or na?? putting that 650cc+ injectors on a naturally aspirated setup is beyond me!
yes turbo.
I have a Honda and a Mitsubishi resistor pack. If any of them might help you, just let me know.
i believe a Mitsu resistor pack is what i will need.
how much?
where did you get it from?
I got it with some turbo goodies a while back. I’m not sure what its for. I am going to where it is on sunday or monday. Give me a shout then and I will grab it for you. 221-4046. Price is 10 bux.
Do you know how many ohm’s your pack will do if you hook a multimeter to it? It should be between 8-12ohms.
k been through THIS last summer.
1 option
dsm, honda 2 most commom packs for low emp injectors. Get it off Jeff or visit pick a part.
2 call active electonics on southside, ask for 4 10ohm 10 watt injectors they are 2$each or so and come in packs of 2.
If you need part # pm me i have it at home.
Do a search on ka-t.org or nico in regards to install . Its as basic as cut a wire sater resistor in.
good luck
