HONDA b series turbo oil feed line length???
I have searched and searched… how damn long do you need a turbo oil feed line to be for a honda engine bay. im runnin a b series engine with a cast bottom mount manifold… i cant seem to find anything… to be more specific, i have a Garrett gt2860rs with Blox manifold, and im running the blox sandwich plate for the oil feed.
HELP!!!
I had the golden eagle sandwhich plate and used about 3 ft of steel braided line and steal had some to work with its just all in how you run it
Thanks, do you think a 30" line will make it? im going to run it beside the engine over the top of the tranny and back around to the blox sandwich plate.
i just found a liquidation sale on earls turbo oil lines it’s a 30" -4an line for cheep. Is yours -3an or -4an? and are you runnin an oil restrictor inline?
mine was -4 and i ran a restrictor, it depends on how low your turbo sits really, keep in mind fittings can lengthen your line a little or restrict it possibly, running around the motor takes a little longer line, than over the valve cover but looks alot better, just get a hold of hybrid for the line the prices are good for it as well
