There’s a banjo fitting on only one end.
---------- Post added at 04:39 PM ---------- Previous post was at 04:32 PM ----------
(I found this on some other 240 forum. Hope it helps)
Cut/paste from notes i’ve saved:
Oil supply line
12mmx1.25 to -6AN union adapter-----EAR-991945
6 AN female x -4 AN male AN reducer fitting-----EAR-989464
90 Degree -4AN hose end-----EAR-309104
Perform-O-Flex -4 AN hose, 3 Foot Length-----EAR-403004 (cut to required length)
GT Oil supply fitting (go to www.atpturbo.com)
Water supply
1/4" hose barb to 1/8" NPT union adapter-----EAR-984004
1/8" NPT female coupler-----EAR-991001
1/8" NPT to -4AN union adapter-----EAR-984004
-4AN straight hose end-----EAR-300104
Perform-O-Flex -4 AN hose, 3 Foot Length-----EAR-403004 (cut to required length, should be able to do the return and supply on the stock DET manifolds)
1/4" NPT to -4AN union adapter-----EAR-981644
ATP banjo water fitting adapters (go to www.atpturbo.com)
Water return
-4AN hose(see above)-----EAR-403004
Oil Return
ATP GT Oil drain fitting and gasket
1/2" NPT to -10AN union adapter-----EAR-981610
-10AN hose end-----EAR-800110
-10AN hose (again this is a 3 foot section which you wont need all of)-----EAR-403010
1/2"BSPT to -10AN union adapter-----Found a place in Florida that deas this fitting http://www.batinc.net/files/un816.pdf
---------- Post added at 04:39 PM ---------- Previous post was at 04:39 PM ----------
Oil supply line
Water supply
Water return
Oil Return
