Coolant return/feed line fittings for t25.
Would any one recommend a place that sells these fittings. I would prefer to pick them up locally.
14mm Banjo to 1/4 NPT
1/4" NPT to 5/16
I am trying to replicate this setup for the coolant return/feed line. I already have the oil stuff covered.
http://www.sr20-forum.com/240sx/3102-oil-coolant-feed-return-line-ka24det.html
If you feel there is a safer/cheaper/more effective way to set this up on a ka24de please comment. Thank you.
couldnt you just use the banjo off the original lines cut it and flare the end so the pipe cant slide off. i think its a safe way to go aslong as u flare the ends.
I probably could but the turbo i bought didn’t come with banjo fittings.
try a local hydraulic shop like motion or paca.
Thanks for the info, i will give them a try.
Brofasco (sp)
