i gota 97 civic sittin here that the speedo jumps to 120 mph and the cars in park i tried 3 speed sensors a cluster and ecu (didnt pay for em so dont start) that i had for the car anyhow its a auto any help?
check grounds… specifically the engine harness ground as well as the pack of power wires under the intake manifold.
it sounds like you blew the welds on your intake. probably low on headlight fluid too.
hada speedo jumin
we be jummin…o yeah… we be jummin man!
Check your alternator voltage.
jumin…
let me clear it up hada=honda juming = jumping i know not funny my bad
Ok first get 5 gallons of gas and a pack of matches…just kidding
try this http://autorepair.about.com/library/faqs/bl022i.htm
it sounds better the other way… we will now call you Bob Marley
thought i put a link to jammin last night ohwell
i added a few grounds and nothin so i took it to pcm auto electric in plum and he said the alt. was charging at 5 to 10 amps so its outside tore apart i expect the alt to be back today or thurs am thanks guys. the gas and matches are on hand for plan b
shut the fuck up, faggot.
get back to the oven
fix it yet? (cleaned)
