Ok so here is the situation. Once in a while the honda STALLS outs while sitting at a light. As soon as it STALLS, it turns right back over like I literally just turned it off. No rough IDLE, no running like crap, literally turns off then turn backs over like nothing happened. Its a 99 honda civic si.
-No check engine lights on
-Running fine
-If it sits over night kind of has a little bit longer cranking time.
-Sending unit has finally gone bad, but I know I WASN’T out of gas because right after it STALLED out, I filled up with 93 and it took 7 gallons
No lights on at all
Here is what I have done:
-Replaced the Battery connections
-Replaced the Fuel Pressure Regulator
-Checked all the grounds, all fine, even wiggled them when car was running to see if they would cause it to stahl out
-Replaced all the VACUUM lines
-Only running 93 gas
