Is 50 psi too much pressure? I don’t know so I’m just asking if you are sure that that’s the pressure the valve will see.
I’m having the same problem with one of my oxygen generators at work. Nobody can figure out why it won’t open, until I checked the spec and a valve that’s spec’d at 7 psi max differential is installed where it will see a 60 psi differential. :ham:
today, i’ll try a p.s that can deal with 10 amps, and maybe a water pump to get to 50 psi. should air vs liquid matter with a solenoid?
edit:
a different P.S. opens both solenoids.
not sure if it was a ground loop, or if the lab p.s was not able to deal with the current. the 25 amp p.s. appears to draw the same current, but the voltage does not drop off lik eit was apparently doing on lab supplies
