Ease of installation. Our turbocharger systems can be installed in 4-6 hours with standard tools and average mechanical ability.
No need for major modifications to your vehicle to fit the turbocharger system. Our systems are designed to bolt on using factory mounts.
Lower underhood temperatures and no need to worry about melting wires, hoses, or other components.
More room under the hood than stock vehicles so that future repair work or modifications will not require the expense of removing the turbo system to allow access to any of the engine components.
Cooler oil to the turbocharger and cooler oil being pumped back to your engine as well as increased oil capacity.
Approximately 500F lower turbocharger temperatures which eliminates the need for a turbo-timer to allow engine to run after car is shut off to cool down turbo and prevent oil and bearing damage that occur when engine is shut off while turbo is still extremely hot.
Denser exhaust gasses to drive the turbocharger turbine wheel more efficiently.
Good intercooler efficiency without the expense, pressure drop, and installation problems associated with a front mounted intercooler.
Turbocharger is exposed to ambient air rather than underhood air which allows for better cooling of turbocharger components.
No need for expensive headers, mufflers, or exhaust systems.
Turbocharger is closer to the tail pipe outlet which provides a better pressure differential across the turbine wheel which promotes better flow across turbine.
Easily converts back to stock in less than 2 hours.
Better weight transfer for increased traction with bulk of system mounted in rear of vehicle rather than up front.
Less noise in the passenger compartment.
Quieter wastegates, especially if vented to atmosphere.
Better engine cooling capacity than with conventional turbo system, especially those with front mounted intercoolers.
Built in intercooling from the heat dissipation through the charge air tubing that is mostly located out of the engine compartment and exposed to ambient air.
No need to add turbo-timers or auxiliary oil system pre-lubrication devices.
What about a speed bump and break off the housing
